[Bounty $1500] SAM2 bring up using TTNN APIs
Issue ID: I_kwDOI9Wqc88AAAABG3LEGg
:memo: Background
This bounty is for bringing up facebook/sam2-hiera-tiny using TTNN APIs on Tenstorrent hardware (Wormhole or Blackhole).
SAM 2 is Meta’s foundation model for promptable visual segmentation (paper). The goal is to enable this model to run on TT hardware in image mode — Hiera image encoder, prompt encoder, and two-way transformer mask decoder. Video tracking (memory encoder/attention/bank) is out of scope
:bullseye: What Success Looks Like
  • Implement the full image-mode pipeline in TTNN: image encoder, prompt encoder, and mask decoder
  • Support point, box, and mask prompts, matching the HF reference numerically (PCC)
  • Measure and report throughput/latency on device, performance repport
Stage 1 — Bring-Up
  • Implement sam2-hiera-tiny (image mode, 1024×1024 input) using TTNN APIs (Python)
  • Model runs on N150 or N300 with no errors
  • Produces valid masks on sample images; verify against the HF reference
Stage 2 — Basic Optimizations
  • Use optimal sharded/interleaved memory configs across encoder and decoder
  • Efficient sharding for patch embedding and transformer blocks
  • Fuse simple ops where possible
  • Store intermediate activations in L1 where beneficial
Stage 3 — Deeper Optimization
  • Maximize core utilization per inference
  • Minimize memory and tensor manipulation overheads
:compass: Guidance & Starting Points
:magnifying_glass_tilted_right: Possible Approaches
  • Start from the HuggingFace Sam2Model / PyTorch reference and port layers one by one to TTNN, validating each submodule’s output against the reference before full integration.
  • Use TTNN profiling tools to identify bottlenecks and fusion opportunities.
:bar_chart: Result Submission Guidelines
Beyond the model implementation itself, contributors must submit the following material as proof of work. However, feel free to open a PR at any time if you want us checking that you are on the right track. Just understand that payout is only made after all 3 stages are completed.
Deliverables:
  • Functional model implementation
  • Validation logs (output correctness)
  • Performance report + header for final review
Links:
:books: Resources
facebook/sam2-hiera-tiny on Hugging Face SAM 2 official repo SAM 2 paper
