This bounty is for bringing up DiffusionDrive
using TTNN APIs on Tenstorrent hardware (Wormhole or Blackhole).
DiffusionDrive is a truncated diffusion model designed for real-time end-to-end autonomous driving.
It replaces the slow, multi-step denoising process of conventional diffusion policies with a lightweight anchored and truncated diffusion process, achieving over 10Γ faster inference while maintaining multi-modal driving behavior and state-of-the-art accuracy.
Without any extra training tricks, DiffusionDrive reaches 88.1 PDMS on the NAVSIM benchmark using the same ResNet-34 backbone, trained via imitation learning on human driving trajectories, and runs at real-time 45 FPS.
For full architectural and algorithmic details, refer to the paper
The goal of this bounty is to enable efficient DiffusionDrive inference on Tenstorrent hardware, allowing users and partners to leverage high-throughput, low-latency execution for end-to-end driving policy and trajectory prediction.
What Success Looks Like
A successful submission will fulfill all requirements in the following stages. Payout is made after all three stages are completed.
Stage 1 β Bring-Up
Implement Diffusion Drive using TTNN APIs (Python).
Model runs on either N150 or N300 hardware with no errors.
Produces valid outputs/ego vehicle trajectories matching the implementation here.
Output is verifiable (visualization + simple metric checks).
Clear instructions for setup and running the model.
Stage 2 β Basic Optimizations
Use optimal sharded/interleaved memory configs and sharding strategy for conv ops in backbone/heads.
Fuse simple ops where possible (e.g., Conv+BN+Activation using TT fused ops).
Refer to TT fused ops for opportunities to optimize.
Target input resolutions: start with 640Γ640Γ3 (or model default).
Ask for help or file issues if ops are missing in TTNN.
Possible Approaches
Start from an existing implementation of the model /the link shared above and port layers one by one to TTNN.
Validate each submoduleβs output against CPU/PyTorch reference before full integration.
Experiment with different sharding strategies and memory configs for convolutions.
Use TTNN profiling tools to identify bottlenecks and areas for fusion.
Open a draft PR early to get feedback on your approach.
Result Submission Guidelines
Beyond the model implementation itself. Contributors must submit the following material as a proof of work. However, feel free to open a PR at any time if you want us checking you are on the right track. Just understand that payout is only made after all 3 stages are completed.
