opened 05:57PM - 10 Nov 25 UTC
closed 06:19PM - 15 Jul 26 UTC
bounty
bounty_difficulty/medium
model bringup
### π Background
This bounty is for bringing up the **AudioX** model using TTNN⦠APIs on Tenstorrent hardware (Wormhole or Blackhole).
AudioX is a unified framework for anything-to-audio generation from HKUST, supporting multimodal control signals. Released in 2025, key features include:
* **Anything-to-audio**: Supports text, video, image, and audio inputs for audio generation
* **Multiple tasks**: Text-to-audio, text-to-music, video-to-audio, video-to-music, audio inpainting, music completion
* **Multimodal Adaptive Fusion**: Novel module for effective fusion of diverse multimodal inputs
* **Large-scale training**: IF-caps dataset with 7 million high-quality samples
* **State-of-the-art performance**: Superior results on AudioCaps, MusicCaps, T2A-bench, and AudioTime benchmarks
* **Diffusion Transformer**: Uses diffusion-based generation with transformer architecture
* **Instruction following**: Handles complex temporal instructions (timestamps, ordering, counting)
* **High quality**: 16 kHz audio output with natural sound quality
AudioX achieves superior performance across benchmarks, especially in text-to-audio and text-to-music generation, demonstrating powerful multimodal control and instruction-following capabilities.
The goal is to enable this model to run on Tenstorrent hardware for high-throughput, low-latency multimodal audio generation .
### π― What Success Looks Like
A successful submission will fulfill all requirements in the following stages. Payout is made after all three stages are completed.
### Stage 1 β Bring-Up
* Implement AudioX using TTNN APIs (Python)
* Implements the full generation pipeline:
* Multimodal encoders (text, video, image, audio)
* Multimodal Adaptive Fusion module
* Diffusion Transformer decoder
* Vocoder for waveform generation
* Model runs on either N150 or N300 Tenstorrent hardware with no errors
* Supports multiple generation modes:
* **Text-to-audio**: Generate sound effects from text descriptions
* **Text-to-music**: Generate music from text prompts
* **Video-to-audio**: Generate audio synchronized with video
* **Video-to-music**: Generate background music for video
* Produces valid 16 kHz audio output on sample inputs
* Output is verifiable (audio quality assessment, compare with PyTorch reference)
* Achieves baseline throughput target:
* At least 20 tokens/second for diffusion sampling
* Generation time < 30 seconds for 10-second audio
* Accuracy evaluation:
* Inception Score comparable to paper results
* Text-audio alignment score > 0.7
* Token-level accuracy > 95% against PyTorch reference
* Audio quality: Natural sound quality and accurate multimodal alignment
* Clear instructions for setup and running the model
### Stage 2 β Basic Optimizations
* Use optimal sharded/interleaved memory configs for transformer layers
* Implement efficient sharding strategy for:
* Text encoder (CLAP or similar)
* Video encoder (if applicable)
* Diffusion Transformer layers
* Attention mechanisms (self and cross-attention)
* Fuse simple ops where possible (e.g., layer normalization, attention patterns, activation functions)
* Store intermediate activations in L1 where beneficial
* Use recommended TTNN/tt-metal diffusion model flows
* Leverage TT library of fused ops for attention and MLP blocks
* Optimize multimodal fusion operations
* Efficient diffusion sampling (DDPM/DDIM)
* Optimize vocoder integration
### Stage 3 β Deeper Optimization
* Maximize core counts used per inference
* Implement deeper TT-specific optimizations:
* Efficient diffusion sampling with fewer steps (DDIM, DPM-Solver)
* Flash Attention or equivalent for attention layers
* Minimize generation latency
* Batch processing for multiple audio generations
* Pipeline multimodal encoding with diffusion sampling
* Optimize cross-modal attention
* Efficient temporal instruction handling
* Minimize memory and TM (tensor manipulation) overheads
* Explore classifier-free guidance optimization
* Document any advanced tuning, known limitations, or trade-offs
* Target stretched goals:
* 50+ tokens/second diffusion sampling
* Generation time < 10 seconds for 10-second audio
* Support for longer audio (30+ seconds)
* Efficient multi-task switching
### π§ Guidance & Starting Points
* Use the [TTNN model bring-up tech report](https://github.com/tenstorrent/tt-metal/blob/main/tech_reports/ttnn/TTNN-model-bringup.md) as your primary reference
* Reference [diffusion model implementations in tt-metal](https://github.com/tenstorrent/tt-metal/tree/main/models/experimental/stable_diffusion) for diffusion patterns
* Reference [transformer implementations in tt-metal](https://github.com/tenstorrent/tt-metal/tree/main/models/demos/wormhole) for transformer patterns
* Use the [AudioX project page](https://zeyuet.github.io/AudioX/) for demos and examples
* Refer to the [AudioX paper (arXiv:2503.10522)](https://arxiv.org/abs/2503.10522) for technical details
* Check [AudioX HuggingFace](https://huggingface.co/AudioX) for model checkpoints
* Check [AudioX GitHub](https://github.com/AudioX) for official code repository
* Refer to [TT Fused ops PR #29236](https://github.com/tenstorrent/tt-metal/pull/29236) for optimization opportunities
* The model architecture consists of:
* **Multimodal encoders**: Separate encoders for text, video, image, audio inputs
* **Multimodal Adaptive Fusion**: Fuses diverse modalities with cross-modal alignment
* **Diffusion Transformer**: Denoising network for audio generation
* **Vocoder**: Converts latent representations to waveforms
* **Classifier-free guidance**: For controllable generation
* Key challenges:
* Multimodal fusion optimization
* Diffusion sampling efficiency (multiple denoising steps)
* Cross-modal attention across different input types
* Temporal instruction handling (timestamps, ordering, counting)
* Vocoder integration
* Long audio generation
* Ask for help or file issues if ops are missing in TTNN
### π Possible Approaches
* Start from the official AudioX implementation and port components sequentially:
1. Text encoder (CLAP or similar)
2. Video/image encoders (if using video-to-audio)
3. Multimodal Adaptive Fusion module
4. Diffusion Transformer (U-Net or DiT architecture)
5. Vocoder integration
6. Diffusion sampling loop (DDPM/DDIM)
7. Classifier-free guidance
* Validate each submodule's output against PyTorch reference before integration
* Experiment with different sharding strategies:
* Attention head sharding
* Sequence length sharding
* Batch dimension sharding for diffusion steps
* Use TTNN profiling tools to identify bottlenecks in:
* Multimodal encoding time
* Fusion module overhead
* Diffusion sampling iterations
* Vocoder latency
* Test diverse use cases:
* Text-to-audio with complex descriptions
* Text-to-music with style instructions
* Video-to-audio synchronization
* Temporal instructions (timestamps, ordering)
* Audio inpainting and music completion
* Open a draft PR early to get feedback on your approach
## π Result Submission Guidelines
Beyond the model implementation itself, contributors must submit the following material as proof of work.
However, feel free to open a PR at any time if you want us checking that you are on the right track.
Just understand that payout is only made after **all 3 stages** are completed.
**Deliverables:**
* Functional model implementation in TTNN
* Validation logs showing output correctness (latent accuracy vs PyTorch)
* Performance report with generation time and quality metrics
* Sample audio outputs comparing TTNN vs PyTorch:
* Text-to-audio examples (sound effects)
* Text-to-music examples (various genres)
* Video-to-audio examples (if implemented)
* Temporal instruction examples (timestamps, ordering)
* Inception Score and other quality metrics
* Performance header for final review
**Links:**
* [Performance Sheet](https://github.com/tenstorrent/tt-metal/blob/main/tech_reports/ttnn/TTNN-model-bringup.md#41-performance-sheet)
* [Perf Header Docs](https://docs.tenstorrent.com/tt-metal/latest/ttnn/ttnn/profiling_ttnn_operations.html#perf-report-headers)
### π Resources
### Model Resources
* [AudioX Project Page](https://zeyuet.github.io/AudioX/)
* [AudioX Paper (arXiv:2503.10522)](https://arxiv.org/abs/2503.10522)
* [AudioX GitHub Repository](https://github.com/AudioX) (check for actual link when available)
* [AudioX HuggingFace Models](https://huggingface.co/AudioX) (check for actual link when available)
* [AudioX Demo](https://huggingface.co/spaces/AudioX/demo) (check for actual link when available)
### Benchmark Resources
* [AudioCaps Dataset](https://audiocaps.github.io/)
* [MusicCaps Dataset](https://www.kaggle.com/datasets/googleai/musiccaps)
* [T2A-bench Benchmark](https://github.com/WillDreamer/T2A-bench)
* [AudioTime Benchmark](https://github.com/audiotime/audiotime)
### TT-Metal Resources
* [TTNN Model Bring-up Tech Report](https://github.com/tenstorrent/tt-metal/blob/main/tech_reports/ttnn/TTNN-model-bringup.md)
* [Diffusion Model Implementations in tt-metal](https://github.com/tenstorrent/tt-metal/tree/main/models/experimental/stable_diffusion)
* [Transformer Implementations in tt-metal](https://github.com/tenstorrent/tt-metal/tree/main/models/demos/wormhole)
* [TT Fused Ops PR #29236](https://github.com/tenstorrent/tt-metal/pull/29236)
* [Performance Report Header](https://docs.tenstorrent.com/tt-metal/latest/ttnn/ttnn/profiling_ttnn_operations.html#perf-report-headers)
Issue ID: I_kwDOI9Wqc87XHo88
Background
This bounty is for bringing up the AudioX model using TTNN APIs on Tenstorrent hardware (Wormhole or Blackhole).
Anything-to-audio : Supports text, video, image, and audio inputs for audio generation
Multiple tasks : Text-to-audio, text-to-music, video-to-audio, video-to-music, audio inpainting, music completion
Multimodal Adaptive Fusion : Novel module for effective fusion of diverse multimodal inputs
Large-scale training : IF-caps dataset with 7 million high-quality samples
State-of-the-art performance : Superior results on AudioCaps, MusicCaps, T2A-bench, and AudioTime benchmarks
Diffusion Transformer : Uses diffusion-based generation with transformer architecture
Instruction following : Handles complex temporal instructions (timestamps, ordering, counting)
High quality : 16 kHz audio output with natural sound quality
Stage 1 β Bring-Up
Text-to-audio : Generate sound effects from text descriptions
Text-to-music : Generate music from text prompts
Video-to-audio : Generate audio synchronized with video
Video-to-music : Generate background music for video
Use the TTNN model bring-up tech report as your primary reference
Reference diffusion model implementations in tt-metal for diffusion patterns
Reference transformer implementations in tt-metal for transformer patterns
Use the AudioX project page for demos and examples
Refer to the AudioX paper (arXiv:2503.10522) for technical details
Check AudioX HuggingFace for model checkpoints
Check AudioX GitHub for official code repository
Refer to TT Fused ops PR #29236 for optimization opportunities
Multimodal encoders : Separate encoders for text, video, image, audio inputs
Multimodal Adaptive Fusion : Fuses diverse modalities with cross-modal alignment
Diffusion Transformer : Denoising network for audio generation
Vocoder : Converts latent representations to waveforms
Classifier-free guidance : For controllable generation
Key challenges:
Vocoder integration
Possible Approaches
Vocoder integration
Validate each submoduleβs output against PyTorch reference before integration
Vocoder latency
Just understand that payout is only made after all 3 stages are completed.
Deliverables:
Links:
Resources
Model Resources
Benchmark Resources
TT-Metal Resources
