Strata Local AI Engine: Can It Run on a Single 12GB GPU?
A new video from Digital Spaceport puts Strata Local AI Engine to the test on a single 12GB VRAM card. The engine, designed for local inference without cloud dependency, is demonstrated running within that tight memory ceiling — no multi-GPU setup, no offloading tricks highlighted as mandatory.
The core question: does it actually fit and perform at usable speeds? Digital Spaceport walks through the setup, benchmarks, and real-world output quality to give a clear yes-or-no picture for anyone with a mid-range card sitting idle.
Verdict lands in the video itself — but the premise holds up well enough to make 12GB a realistic floor rather than just a theoretical minimum.
Publish Date: 2026-10-12-17:10
