It should provide the following parts for successful nix support
Continue the maintainence of above packages
Add flake.nix files for development. (For instance, this would replace the function of install_dependencies.sh in tt-metal repo)
(Optional) Add another flake.nix file that will help the installation of whole TT stack
pinging @jberkowitzTT
Describe alternatives you’ve considered
No response
Additional context
Note: In NixOS, 4th step might be especially helpful since in NixOS Filesystem Hierarchy Standard (FHS) is not present (so usual filepaths like /opt/tenstorrent would not work).
