# \[Bounty $1500\] LLVC (Low-Latency Low-Resource Voice Conversion) bring up using TTNN APIs
**URL:** <https://www.deusop.org/t/bounty-1500-llvc-low-latency-low-resource-voice-conversion-bring-up-using-ttnn-apis/211>\
**Category:** Bounties\
**Tags:** completed\
**Created:** [July 11, 2026, 11:32am UTC](https://www.deusop.org/t/bounty-1500-llvc-low-latency-low-resource-voice-conversion-bring-up-using-ttnn-apis/211 "2026-07-11T11:32:27Z")\
**Posts on this page:** 1\
**Page:** 1
<div class="post-metadata">
**Author:** ![ClaraFlux](https://www.deusop.org/user_avatar/www.deusop.org/claraflux/32/10_2.png) [@ClaraFlux](https://www.deusop.org/u/ClaraFlux)\
**Post date:** [July 11, 2026, 11:32am UTC](https://www.deusop.org/t/bounty-1500-llvc-low-latency-low-resource-voice-conversion-bring-up-using-ttnn-apis/211/1 "2026-07-11T11:32:28Z")
</div>
> <https://github.com/tenstorrent/tt-metal/issues/32187>
> \### 📝 Background
> This bounty is for bringing up the \*\*LLVC (Low-Latency Low-Res…ource Voice Conversion)\*\* model using TTNN APIs on Tenstorrent hardware (Wormhole or Blackhole).
> LLVC is a real-time voice conversion model from Koe AI specifically optimized for low latency and CPU efficiency. Published in 2023, key features include:
> \* \*\*Ultra-low latency\*\*: Designed for real-time voice conversion with minimal delay
> \* \*\*CPU-optimized\*\*: Efficient enough to run on CPU in real-time
> \* \*\*Streaming support\*\*: True streaming inference with chunked processing
> \* \*\*High quality\*\*: Natural voice conversion while maintaining low latency
> \* \*\*Compatible architecture\*\*: Based on RVC/QuickVC with optimizations
> \* \*\*Small model size\*\*: Low resource requirements for edge deployment
> \* \*\*No F0 dependency\*\*: Optional pitch-independent conversion mode
> \* \*\*MIT License\*\*: Free for commercial use
> LLVC achieves real-time factor (RTF) \< 0.1 on CPU, making it suitable for live applications like real-time dubbing, streaming, gaming voice chat, and interactive voice applications.
> The goal is to enable this model to run on TT hardware for ultra-high-throughput, ultra-low-latency voice conversion optimized for real-time applications.
> \### 🎯 What Success Looks Like
> A successful submission will fulfill all requirements in the following stages. Payout is made after all three stages are completed.
> \### Stage 1 — Bring-Up
> \* Implement LLVC using TTNN APIs (Python)
> \* Implements the full generation pipeline:
> \* Lightweight encoder (optimized for low latency)
> \* Streaming-capable architecture
> \* Efficient decoder
> \* Optional pitch extraction (F0-based and F0-free modes)
> \* Vocoder integration
> \* Model runs on either N150 or N300 Tenstorrent hardware with no errors
> \* Supports both modes:
> \* \*\*Streaming mode\*\*: Real-time conversion with chunked processing
> \* \*\*Non-streaming mode\*\*: Full-context conversion
> \* Produces valid converted audio output
> \* Output is verifiable (audio quality assessment, compare with PyTorch reference)
> \* Achieves baseline throughput target:
> \* At least 50 tokens/second for decoder generation
> \* Real-time factor (RTF) \< 0.3 for streaming mode
> \* Latency \< 100ms for streaming chunks
> \* Accuracy evaluation:
> \* Speaker similarity \> 70% (cosine similarity)
> \* Content preservation: WER \< 3.0
> \* Token-level accuracy \> 95% against PyTorch reference
> \* Audio quality: Natural prosody with minimal artifacts despite low latency
> \* Clear instructions for setup and running the model
> \### Stage 2 — Basic Optimizations
> \* Use optimal sharded/interleaved memory configs for encoder-decoder layers
> \* Implement efficient sharding strategy for:
> \* Lightweight encoder layers
> \* Decoder layers optimized for streaming
> \* Convolutional layers with causal padding
> \* Cached convolution states for streaming
> \* Optional pitch extraction module
> \* Fuse simple ops where possible (e.g., layer normalization, activation functions)
> \* Store intermediate activations in L1 where beneficial
> \* Use recommended TTNN/tt-metal flows for streaming audio models
> \* Leverage TT library of fused ops for convolution blocks
> \* Optimize chunk-based processing for streaming
> \* Efficient state management for causal convolutions
> \* Optimize vocoder integration
> \### Stage 3 — Deeper Optimization
> \* Maximize core counts used per inference
> \* Implement deeper TT-specific optimizations:
> \* Ultra-low latency streaming (minimize chunk processing time)
> \* Efficient causal convolution with state caching
> \* Flash Attention or equivalent where applicable
> \* Minimize voice conversion latency per chunk
> \* Batch processing for multiple concurrent streams
> \* Pipeline encoder/decoder/vocoder stages
> \* Optimize memory footprint for edge deployment
> \* Minimize memory and TM (tensor manipulation) overheads
> \* Explore look-ahead strategies for quality vs latency trade-off
> \* Document any advanced tuning, known limitations, or trade-offs
> \* Target stretched goals:
> \* 100+ tokens/second generation speed
> \* RTF \< 0.1 for streaming mode (match CPU performance)
> \* Latency \< 50ms for streaming chunks
> \* Support for 10+ concurrent streams
> \### 🧭 Guidance & Starting Points
> \* Use the \[TTNN model bring-up tech report\](https://github.com/tenstorrent/tt-metal/blob/main/tech\_reports/ttnn/TTNN-model-bringup.md) as your primary reference
> \* Reference \[streaming audio model patterns in tt-metal\](https://github.com/tenstorrent/tt-metal/tree/main/models/demos) for streaming architectures
> \* Use the \[official LLVC repository\](https://github.com/KoeAI/LLVC) for model architecture details
> \* Refer to the \[LLVC paper (arXiv:2311.00873)\](https://arxiv.org/abs/2311.00873) for technical details
> \* Check \[LLVC demo page\](https://koeai.github.io/llvc-demo/) for audio samples
> \* Refer to \[TT Fused ops PR #29236\](https://github.com/tenstorrent/tt-metal/pull/29236) for optimization opportunities
> \* The model architecture consists of:
> \* \*\*Lightweight encoder\*\*: Optimized convolutional layers with reduced complexity
> \* \*\*Cached convolutions\*\*: State management for causal streaming inference
> \* \*\*Efficient decoder\*\*: Minimal layers for low latency
> \* \*\*Optional F0 module\*\*: Pitch extraction when needed
> \* \*\*Vocoder\*\*: HiFi-GAN or similar (can be shared with other models)
> \* Key challenges:
> \* Ultra-low latency requirements (\< 100ms)
> \* Streaming inference with causal convolutions
> \* State management across chunks
> \* Quality vs latency trade-off
> \* Vocoder integration and optimization
> \* Small model size constraints
> \* Streaming parameters:
> \* \`window\_ms\`: Chunk size in milliseconds (affects latency)
> \* \`extra\_convert\_size\`: Extra context for quality (affects latency)
> \* Ask for help or file issues if ops are missing in TTNN
> \### 🔎 Possible Approaches
> \* Start from the \[official LLVC repository\](https://github.com/KoeAI/LLVC) and port components sequentially:
> 1. Lightweight encoder (optimized convolutions)
> 2. Cached convolution layers for streaming
> 3. Efficient decoder
> 4. Optional pitch extraction (F0 mode)
> 5. Vocoder integration
> 6. Streaming inference pipeline with state management
> \* Validate each submodule's output against PyTorch reference before integration
> \* Experiment with different sharding strategies:
> \* Channel sharding for convolutions
> \* Sequence length sharding for chunks
> \* Minimize cross-chip communication
> \* Use TTNN profiling tools to identify bottlenecks in:
> \* Per-chunk processing time (critical metric)
> \* Encoder latency
> \* Decoder latency
> \* State management overhead
> \* Vocoder latency
> \* Test diverse use cases:
> \* Streaming mode with various chunk sizes (50ms, 100ms, 200ms)
> \* Non-streaming mode for comparison
> \* F0-based vs F0-free modes
> \* Multiple concurrent streams
> \* Real-time conversion scenarios
> \* Open a draft PR early to get feedback on your approach
> \## 📊 Result Submission Guidelines
> Beyond the model implementation itself, contributors must submit the following material as proof of work.
> However, feel free to open a PR at any time if you want us checking that you are on the right track.
> Just understand that payout is only made after \*\*all 3 stages\*\* are completed.
> \*\*Deliverables:\*\*
> \- Functional model implementation
> \- Validation logs (output correctness)
> \- Performance report + header for final review
> \*\*Links:\*\*
> \- \[Performance Sheet\](https://github.com/tenstorrent/tt-metal/blob/main/tech\_reports/ttnn/TTNN-model-bringup.md#41-performance-sheet)
> \- \[Perf Header Docs\](https://docs.tenstorrent.com/tt-metal/latest/ttnn/ttnn/profiling\_ttnn\_operations.html#perf-report-headers)
> \### 📚 Resources
> \### Model Resources
> \* \[LLVC Official Repository\](https://github.com/KoeAI/LLVC)
> \* \[LLVC Paper (arXiv:2311.00873)\](https://arxiv.org/abs/2311.00873)
> \* \[LLVC Demo Page\](https://koeai.github.io/llvc-demo/)
> \* \[LLVC Paper PDF\](https://koe.ai/papers/llvc.pdf)
> \* \[Koe AI Homepage\](https://koe.ai/)
> \* \[RVC Repository (related)\](https://github.com/RVC-Project/Retrieval-based-Voice-Conversion-WebUI)
> \### TT-Metal Resources
> \* \[TTNN Model Bring-up Tech Report\](https://github.com/tenstorrent/tt-metal/blob/main/tech\_reports/ttnn/TTNN-model-bringup.md)
> \* \[Streaming Audio Models in tt-metal\](https://github.com/tenstorrent/tt-metal/tree/main/models/demos)
> \* \[TT Fused Ops PR #29236\](https://github.com/tenstorrent/tt-metal/pull/29236)
> \* \[Performance Report Header\](https://docs.tenstorrent.com/tt-metal/latest/ttnn/ttnn/profiling\_ttnn\_operations.html#perf-report-headers)
Issue ID: I\_kwDOI9Wqc87XHw0e
### 📝 Background
This bounty is for bringing up the **LLVC (Low-Latency Low-Resource Voice Conversion)** model using TTNN APIs on Tenstorrent hardware (Wormhole or Blackhole).
- **Ultra-low latency** : Designed for real-time voice conversion with minimal delay
- **CPU-optimized** : Efficient enough to run on CPU in real-time
- **Streaming support** : True streaming inference with chunked processing
- **High quality** : Natural voice conversion while maintaining low latency
- **Compatible architecture** : Based on RVC/QuickVC with optimizations
- **Small model size** : Low resource requirements for edge deployment
- **No F0 dependency** : Optional pitch-independent conversion mode
- **MIT License** : Free for commercial use
- Implement LLVC using TTNN APIs (Python)
- Implements the full generation pipeline:
  - Lightweight encoder (optimized for low latency)
  - Streaming-capable architecture
  - Efficient decoder
  - Optional pitch extraction (F0-based and F0-free modes)
  - Vocoder integration
- Model runs on either N150 or N300 Tenstorrent hardware with no errors
- Supports both modes:
  - **Streaming mode** : Real-time conversion with chunked processing
  - **Non-streaming mode** : Full-context conversion
- Produces valid converted audio output
- Output is verifiable (audio quality assessment, compare with PyTorch reference)
- Achieves baseline throughput target:
  - At least 50 tokens/second for decoder generation
  - Real-time factor (RTF) \< 0.3 for streaming mode
  - Latency \< 100ms for streaming chunks
- Accuracy evaluation:
  - Speaker similarity \> 70% (cosine similarity)
  - Content preservation: WER \< 3.0
  - Token-level accuracy \> 95% against PyTorch reference
- Audio quality: Natural prosody with minimal artifacts despite low latency
- Clear instructions for setup and running the model
- Use optimal sharded/interleaved memory configs for encoder-decoder layers
- Implement efficient sharding strategy for:
  - Lightweight encoder layers
  - Decoder layers optimized for streaming
  - Convolutional layers with causal padding
  - Cached convolution states for streaming
  - Optional pitch extraction module
- Fuse simple ops where possible (e.g., layer normalization, activation functions)
- Store intermediate activations in L1 where beneficial
- Use recommended TTNN/tt-metal flows for streaming audio models
- Leverage TT library of fused ops for convolution blocks
- Optimize chunk-based processing for streaming
- Efficient state management for causal convolutions
- Optimize vocoder integration
- Maximize core counts used per inference
- Implement deeper TT-specific optimizations:
  - Ultra-low latency streaming (minimize chunk processing time)
  - Efficient causal convolution with state caching
  - Flash Attention or equivalent where applicable
  - Minimize voice conversion latency per chunk
  - Batch processing for multiple concurrent streams
  - Pipeline encoder/decoder/vocoder stages
  - Optimize memory footprint for edge deployment
- Minimize memory and TM (tensor manipulation) overheads
- Explore look-ahead strategies for quality vs latency trade-off
- Document any advanced tuning, known limitations, or trade-offs
- Target stretched goals:
  - 100+ tokens/second generation speed
  - RTF \< 0.1 for streaming mode (match CPU performance)
  - Latency \< 50ms for streaming chunks
  - Support for 10+ concurrent streams
- Use the [TTNN model bring-up tech report](https://github.com/tenstorrent/tt-metal/blob/main/tech_reports/ttnn/TTNN-model-bringup.md) as your primary reference
- Reference [streaming audio model patterns in tt-metal](https://github.com/tenstorrent/tt-metal/tree/main/models/demos) for streaming architectures
- Use the [official LLVC repository](https://github.com/KoeAI/LLVC) for model architecture details
- Refer to the [LLVC paper (arXiv:2311.00873)](https://arxiv.org/abs/2311.00873) for technical details
- Check [LLVC demo page](https://koeai.github.io/llvc-demo/) for audio samples
- Refer to [TT Fused ops PR #29236](https://github.com/tenstorrent/tt-metal/pull/29236) for optimization opportunities
- The model architecture consists of:
  - **Lightweight encoder** : Optimized convolutional layers with reduced complexity
  - **Cached convolutions** : State management for causal streaming inference
  - **Efficient decoder** : Minimal layers for low latency
  - **Optional F0 module** : Pitch extraction when needed
  - **Vocoder** : HiFi-GAN or similar (can be shared with other models)
- Key challenges:
  - Ultra-low latency requirements (\< 100ms)
  - Streaming inference with causal convolutions
  - State management across chunks
  - Quality vs latency trade-off
  - Vocoder integration and optimization
  - Small model size constraints
- Streaming parameters:
  - `window_ms`: Chunk size in milliseconds (affects latency)
  - `extra_convert_size`: Extra context for quality (affects latency)
- Ask for help or file issues if ops are missing in TTNN
- Start from the [official LLVC repository](https://github.com/KoeAI/LLVC) and port components sequentially:
- Validate each submodule’s output against PyTorch reference before integration
- Experiment with different sharding strategies:
  - Channel sharding for convolutions
  - Sequence length sharding for chunks
  - Minimize cross-chip communication
- Use TTNN profiling tools to identify bottlenecks in:
  - Per-chunk processing time (critical metric)
  - Encoder latency
  - Decoder latency
  - State management overhead
  - Vocoder latency
- Test diverse use cases:
  - Streaming mode with various chunk sizes (50ms, 100ms, 200ms)
  - Non-streaming mode for comparison
  - F0-based vs F0-free modes
  - Multiple concurrent streams
  - Real-time conversion scenarios
- Open a draft PR early to get feedback on your approach
Beyond the model implementation itself, contributors must submit the following material as proof of work. However, feel free to open a PR at any time if you want us checking that you are on the right track. Just understand that payout is only made after **all 3 stages** are completed.
**Deliverables:**
**Links:**
- [Performance Sheet](https://github.com/tenstorrent/tt-metal/blob/main/tech_reports/ttnn/TTNN-model-bringup.md#41-performance-sheet)
- [Perf Header Docs](https://docs.tenstorrent.com/tt-metal/latest/ttnn/ttnn/profiling_ttnn_operations.html#perf-report-headers)
### 📚 Resources
### Model Resources
- [LLVC Official Repository](https://github.com/KoeAI/LLVC)
- [LLVC Paper (arXiv:2311.00873)](https://arxiv.org/abs/2311.00873)
- [LLVC Demo Page](https://koeai.github.io/llvc-demo/)
- [LLVC Paper PDF](https://koe.ai/papers/llvc.pdf)
- [Koe AI Homepage](https://koe.ai/)
- [RVC Repository (related)](https://github.com/RVC-Project/Retrieval-based-Voice-Conversion-WebUI)
- [TTNN Model Bring-up Tech Report](https://github.com/tenstorrent/tt-metal/blob/main/tech_reports/ttnn/TTNN-model-bringup.md)
- [Streaming Audio Models in tt-metal](https://github.com/tenstorrent/tt-metal/tree/main/models/demos)
- [TT Fused Ops PR #29236](https://github.com/tenstorrent/tt-metal/pull/29236)
- [Performance Report Header](https://docs.tenstorrent.com/tt-metal/latest/ttnn/ttnn/profiling_ttnn_operations.html#perf-report-headers)
